Dunes and Dune Machines Discussion on dunes and dune machines.
a ? for those experienced with running ultra lights.
Old Sep 20, 2004 | 08:43 PM
duneittilludie's Avatar
Default a ? for those experienced with running ultra lights.
I know i can and i have searched for information on this subject but i would like the most current information possible as i am looking to buy ultra lights soon.I have a 690 raptor that according to my builder should be putting out about 60 HP and i have no reason to doubt him judging by the performance that i am getting.My question is if i am running 10 paddle (regular?) haulers now which seem to work well what would be a good choice in the ultra light?My raptor is used probably 90% of the time for uphill sand dragging at anywhere from 300 feet to about 600 feet in length.Another question i have is should i use the .125 wheels with the ultra light as it is the lightest?And my last question is with the HP that i have how much of a gain should i expect to see with ultra lights in a 300 foot race with all else being equal?Thanks.
Old Sep 21, 2004 | 01:29 PM
1BADRAPTOR's Avatar
8 paddle ultra lites on 125 rims, gear down to pull the high gears if you can, pick up about 3 to 4 bikes ... [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 21, 2004 | 03:28 PM
LOWBOWTIE's Avatar
1bad is right 8 paddles would work cool! I have 9's and sometimes they are a bit much when the sand is wet.
Old Sep 21, 2004 | 11:20 PM
Thanks for the responses.Are there a few different kinds of ultra lights as far as weight or a paricular cut as with some other tires.As you can probably tell the ultra light tire is very new to me so some of my questions may seem obvious to those of you in the know but for me any specifics will be helpful.
Old Sep 21, 2004 | 11:50 PM
scrambler123's Avatar
is the nankang carcas what is used for ultralights?
Old Sep 22, 2004 | 12:11 AM
homdaddy's Avatar
i run 12 paddle ultralights on my 740 with 12-44 0r 12-42 gearing and have awsome 2nd gear holeshots
Old Sep 22, 2004 | 05:18 PM
1BADRAPTOR's Avatar
I like the 12/42 gearing with that, it carries all the gears strong till 4th where i stay pinned wide open, great gearing..especially with 22 inch tires...
ULtra lites now are made with a heavier carcus, maybe a 1LB heavier or more but not a big diffrence, to the drag racer every litte bit counts...
Old Sep 25, 2004 | 05:58 AM
DaBeechMan's Avatar
they make the ultra light and a bead to bead. The ultralight is obviously lighter.
Id go with an 8 paddle with a 71-73 RO. Find the old style if you can as they are 3-4lbs lighter per set.
Old Sep 25, 2004 | 12:49 PM
DaBeechMan-Do you have any suggestions on where i could find a set of the tires you suggested?
Old Sep 26, 2004 | 05:09 AM
DaBeechMan's Avatar
PM me
