Who makes the best Bore amd stroke for a raptor
No single builder has a lock on specific big bore parts so the question of "who" makes the best stroker is moot, the components are available to build any combination you can afford. Things like porting and cam choice is where Raptor builders set themselves apart from the others, they all use the same components but the end results can be very different.
The cheapest big bore stroker uses the Hotcams 4mm crank/rod in a 102mm (686) bore for a 720cc stroker. There are more than a few running a +4mm stroker crank/rod in a 105mm (727) bore for a 760cc stroker. Recent talk is a +6mm stroker crank/rod with a 106mm (740) bore for a 800cc stroker, I haven't seen one run yet.
Brent at Dirtworx racing which is a local guy built a 6mm stroked 686 whick i think is a 730 and it runs very hard! The only thing he regrets doing is taking out the counterbalancer! the whole bike is a rattle trap now!
TLC
Jul 11, 2015 02:28 AM
