Dunes and Dune Machines Discussion on dunes and dune machines.
needhelp to chose a paddle
Old Dec 30, 2007 | 10:53 PM
graveycon's Avatar
Default needhelp to chose a paddle
i have a suzuki ltz 400 with a 440 kit on it . please suguest a good paddle for me to run to get max eficency. thank you very much
Old Dec 31, 2007 | 12:51 AM
cynick's Avatar
My all time favorite are Skat trak extreme haulers. Some will say they don't slide well but if you get used to them they slide just as well as anything else. But for me if you don't feel comfortable with them my second choice would be Sandstars.
You will find many opinions but that is mine.
Old Dec 31, 2007 | 07:22 AM
cataway's Avatar
its hard to go wrong with Skat trak extremes,you could find that 8 paddles may be
a little much unless you +your swingarm, wheelies tend to get to easy with the stock setup,as well what sand are you going to run has some thing to do with it.
there are some kinds of paddle tires that i would not get but some times it has to do with how much your able to spend and how often you get to ride sand. becare full of ebay ,i have seen guys pay more for used tires than what they could of gotten then new from a mail order.
Old Dec 31, 2007 | 12:13 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Depends on how and where you ride!
First off, I like the buffed down Skat-Traks over the new generation of molded tires. The Skats are way way lighter, and weight of any kind is your enemy in the dunes....especially weight on your wheel.
If you are a drag racer and just want to go fast in a straight line, then one of the straight paddles are great.
If you shoot bowls and do a lot of turns and manuevering, then the V-shaped are the way to go.
On my Z400, I ran 8-paddle Edges and they were superb!
Old Jan 1, 2008 | 09:29 PM
graveycon's Avatar
thank you very much i ride at silver lake sand dunes in michigan and only make it there about 5 times a year.
Old Apr 17, 2008 | 11:33 PM
trxguy9780's Avatar
the haulers are the best. but they are kinda spendy, but it depnds if your going to be riding trails at the dunes, hill climbin, or draggin. if you want to hillclimb/drag you'll definatly want some kind of straight blades, for some good cheap ones get AMS sand snakes. if you are wanting more control like turning then get some v-blades, good brand is skat trak.
Old Apr 21, 2008 | 12:49 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
You should look into Skat Trak Gliders, they are light weight and have a shorter blade height than haulers or extremes, which is good for 400cc machines. I even know a guy that says he's faster in sand with gliders than haulers on a built Raptor 700, so just to give you an idea. Good luck!
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Aug 25, 2015 11:16 PM
BlackHawk
Feb 10, 2001 09:33 PM
