Originally Posted by Troyboy68
(Post 2883171)
Hey that looks great! i never knew they made that,then agian this whole plowing with an ATV is new to me,thanks im gonna order one up.
What I did was used a tennis ball as a winch saver. Just located one & drilled two holes & threaded the cable thru it. Works fine so far. No breaks. |
Originally Posted by Burndog
(Post 2883710)
(Post 2883296)
WOW! thats insane snow! you need a tractor never mind a ATV lol,, you must be next to Ft.Drum i used to do my summer drills over there with the national guards,we used to take the 1000 island ferry tour on a sunday,very nice up there,, we get alot of snow too,but heck,not 5 ft in a week:eek:, well take good care of the Eiger,ttyl.-
cable
I've been thru cables and broken ropes just changed to a tow strap works great. Purchased 25' strap 3" wide from Fleet Farm for $18.00 cut 10' off and hooked to winch works great won't break its rated for 5,000 # took balance of 15' and had canvas shop sew loop on ($5.00) so I have the 15' pull strap plus the new winch strap. Cheap fix
lifting plow too high
A great way to keep from lifting your plow too high and pulling your cable clamp into your winch I cut a 1x3 and straped it to my front rack lifted the plow to the highest point that I wanted to go measured down from the 1x3 to the top of the plow cut a peice of 1x3 that long and screwed it to the 1x3 that i straped to the rack then when when you lift your plow until it touches the wood and you know it at its max hight
Thanks for your tips guys,, im actually getting the hang of it now,i learned that i cant tork it all the way,so now i bring it up 3/4 and it seems fine,, then i pop the plow off and hit the trails! oh yaaaa! lol.
