1991 honda cbr 600f2
Old Jun 13, 2011 | 02:10 PM
pred5hondo's Avatar
Default 1991 honda cbr 600f2
how do i tighten the chain on it anyone im kinda of new to the rocket scene but any advise would help
Old Jun 13, 2011 | 07:44 PM
PissAnt's Avatar
Step 1 - Check the chain slack, to do this you will need to use your ruler. To measure the chain slack, find the midpoint between the countershaft and rear sprockets; Lift up the chain up and then push it down, take these measurements between the highest one to the lowest one. If your slack isn't around 25 - 35mm or 1 - 1 3/8in, you will need to proceed to step 2.
Step 2 - Clean and lube the chain beforehand (how-to).
Step 3 - Loosen the rear right axle nut with the 27mm. DO NOT REMOVE THE NUT.
Step 4 - Once loose, go to the left side and use the 8mm socket on the adjusting bolt
Step 5 - Turn the bolt until the chain tightens or loosen. Do not make big turns, do bits by bits and check the chain tension every turn. When appropriate slack is obtained, do the same position on the right side. MAKE SURE BOTH SIDES ARE ALIGNED WITH EACHOTHER. Looking at the bar on the indicator helps.
Note: If the indicator is in the red zone, you might have to change your chain and sprockets. You may also adjust the screws all the way in and counting the flats on the head as you make the adjustment.
Step 6 - Now turn the rear wheel and measure the chain in two or three more places to make sure it doesn't have any stuck links or uneven stretching. If the chain has dramatically looser or tighter sections, you will need to replace it.
Step 7 - You will now need the 22mm socket or wrench to hold the rear left axle bolt. The only purpose of this is to stop the bolt from moving around when you tighten on the right side. Use the 27mm on the right side and start tighten it up while managing with the other hand (or get someone) to block the left bolt from moving. DO NOT TIGHTEN IT UP VERY HARD YET. Check the slack and indicator on both sides again, if it hasn't changed, proceed to tighten the nut harder.
Step 8 - Roll the bike forwards and backwards in neutral, and check for any malfunctions. Lube the chain again if you want to.
Step 9 - GO RIDE.
wendal
May 9, 2024 09:29 PM
NewGuy2481
Oct 6, 2015 05:54 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
