help please
Old May 31, 2014 | 05:05 PM
bojo5321's Avatar
Default help please
I have a e-ton viper 90 not sure if the year I bought it and had to hit write the ignition because my son list the only key but my problem is I had it running the other day and it ran perfect I found it it was 2 stroke because I had straight gas in it added 2 stroke oil and now I can't get it to run for the life of me it ran fir about ten minutes and shut off haven't got it to start back up since please help
Old May 31, 2014 | 08:28 PM
brumbear's Avatar
what was your mixture and check compression you may have holed a piston
Old May 31, 2014 | 08:33 PM
bojo5321's Avatar
3.2 to one ratio and it pushes my finger of the spark plug hole it was running in straight gas but for like 5 min tops I thought it was 4 stroke when I mixed the gas is when I started having problems I think one off the jets it's clogged in the carburetor it pushes fuel out the air breather side I don't no anything about the carburetor though
Old May 31, 2014 | 09:16 PM
I'd still do a compression check. If it ran for 5 minutes on straight gas,that may be long enough to do damage to rings,piston,etc. If you just dumped oil in the gas tank and shook it around, it may not be mixed thorough enough also. 2 strokes have to have that proper oil/gas mix..
Old May 31, 2014 | 10:00 PM
bojo5321's Avatar
I drained it then mixed it
