Looking for advice
So I've been riding ATV's basically my whole but very sporadically. I'm about to become a very avid rider however my knowledge of the machines beyond gas, break, shift, is limited. I'm looking to buy a couple ATV's this month. Just looking for opinions, advice, like I said no knowledge. Like what's better 2 stroke or 4? And why? And what would be a better ATV, Honda TRX, or Yamaha Raptor
Definitly go with the 4 stroke becuase they are less maintanince better fuel efficency and if i were you go with honda all day they are reliable amd good working four wheelers and buy utilitys if ur trying to make money everyone loves a honda 4x4 dont get yamahas just a crappy fourwheeler esspecially the motors
What raptor and trx are you looking at? There are a few models available under these names and they all appeal to a different demographic. Your riding style, terrain and mechanical ability should be the deciding factors. You can never go wrong with a Honda or a yamaha. The 2 most trusted names in the industry, especially when it comes to sport bikes
Kj it really depends on the riding your doing? I like 4 stroke w/CVT trans and awd with independent suspension.
This allows me not to have to switch gears or clutch or both without to much hassle in the rocks which in the Northeast are very prevalent. The all wheel drive is a plus no matter what the independent suspension is a POSH ride!!!
AND I enjoy reverse!!!!
Sport quads have a little lower clearance some have no reverse and solid axles with gears semi auto or clutch and 2 and four stroke motors, I just prefer the utility for what I do which is mostly trail riding.
The 2 stroke motor has no valves other than a reed system and fires every other stroke of the piston oil must be mixxed with the fuel or it gets 2 hot ( 2 cycle oil). The motor produces twice the power genrally but wears out quite quickly on the top end.
The 4 stroke has a valve train and fires every 4th rotation of the piston (intake,compression, fire, exhaust) it has more torque less revs and way less heat so you don't have to mix fuel straight gas is fine.
Hope that helps
Dave
Hope that helps
Dave
If you do wind up buying used, you really wind up at the mercy of whoever had the quad before you. Some may have had the crap ridden out of them, but were taken care of and mechanically are in good shape. Some may have just been used to putt around on, but all they ever did was add gas. Looks good but you could be running on oil 5 years old.
Ask if they have any maintenance records and manuals. Chances are, the records aren't going to be kept, but if they have a manual, it's a sign they did more than just add gas.
You wanna thrill, ride 2 strokes, 50% more usable power and easy maintenance, 4 stroke definitely more user friendly. Most Two strokes MUST be tuned for any changes in elevation of more than a few hundred feet. Four strokes fuel injected, electric start, reverse, very pug and play. But heavy as can be. My LT500 zilla weighs 100 lbs less than my 700r Raptor, makes double the HP, and I can pull the jug with the tank and head still on.
