Big Bear '07 HELP
Old Apr 19, 2015 | 09:51 PM
skedhead's Avatar
Default Big Bear '07 HELP
So basically this Four wheeler has not been ridden for about 1 & a half Years .....
So i figure it might not work when i try to start it up. It immediately starts up perfectly fine , but then i notice when i try to give it gas only lets me go about 1/5 to 1/8 at the most. But it is totally Random , sometimes it will let me give it full gas and rev it but other times when i try to give it gas it just will die if i hold it. I had a Flashing red light on the Upper right corner but it went away... Just not sure what to do...
Old Apr 19, 2015 | 10:05 PM
Trash in the carb probably floating around and partially stopping up the jets. You can try to clean the jets,blow out a all the passage ways,but after a year and a half best to just install a new carb kit and be done with it. Several on ebay.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
