Winching
Old Mar 30, 2016 | 05:03 PM
  #21
jgar's Avatar
Originally Posted by Zrock
Pulling out of snow like that is killer on the winch. Last time i was that stuck a 30 second pull took my battery down enough to set the efi light on my quad and also broke the rope. 2 hours to get out and turned around
Yes it is! When I was trying to winch myself out the 500 was running at 1/3 throttle to keep the battery charged. My winch is only a 2k lb warn and frankly I was pissed at how wimpy it is.
After getting stuck like that I firmly believe that winches provide a false sense of security. You look at a 2k or 3k lb winch and think it will pull out a little quad, not really when you take into account the resistance from whatever you are stuck in.
When my bud saved me we had to strap his Grizz 700 to a tree. He was pulling in reverse while using his 3k lb winch and I was on my popo trying to back out.
Moose has the answer! A winch with out a ****** block is basically useless.
Old Mar 30, 2016 | 05:16 PM
  #22
jgar's Avatar
At least you had a way to start a fire and keep warm until help arrived.
And cell service!!!
Before getting stuck like that I never took your lack of winching gear jabs seriously . Now I always bring recovery gear and have done a fair amount of research on the subject of winching techniques and tools.
Old Mar 30, 2016 | 05:26 PM
  #23
jgar's Avatar
Originally Posted by greg74
So basically what everyone is saying is that if you're really stuck, a winch really won't get you out. Its just too much stress on the winch motor and your battery. A winch assists you in getting out of a tough spot, it won't bail you out if you get really buried in mud or snow.
Correct, a winch on its own will only help if you are mildly stuck. Thats why I say you need lift. If you can get the front of an atv out of whatever is holding it back you have drastically reduced the resistance. Thus giving a little 2k-3k lb winch a fighting chance.
Old Mar 31, 2016 | 12:37 AM
  #24
greg74's Avatar
I can imagine my winch will get me out of pretty much any situation I get myself into. Unless I break another cv shaft and simply don't have any power but it still should get me out of a moderate stuck situation. I'm not planning on sinking it in a pond or 3ft of snow. Low range, 4x4 diff-lock and probably getting off the machine to give it less weight to drag out will help the winch out too.
Old Mar 31, 2016 | 09:50 AM
  #25
Zrock's Avatar
Super Quad Patrol
By itself if your really suck no the winch alone will not get you out.. This is where you need the ****** blocks and extra straps to double or triple up your line.. This doubles you pulling power. With the right equipment and use a winch will get you out of 99% of trouble
Old Mar 31, 2016 | 10:03 AM
  #26
This is an example of low strain on a winch. CNCPro got high centered on a nice piece of New England Granite. Not enough traction to go forward or backward, and two guys pushing didn't get it off (aluminum skid plates and granite). I pulled him off the rock without too much strain as it was just that small bit of resistance to break. Note: I didn't put a jacket on the line. Just noticed that. Not too bright on my part.
Old Mar 31, 2016 | 10:06 AM
  #27
This is where we would typically pull out the ****** block pulley to get the quad out. A sled came by and helped us get it out. Could smell his drive belt burning....
Old Mar 31, 2016 | 08:38 PM
  #28
jgar's Avatar
No one plans on getting stuck. Awesome tires, 4x4, diff lock wont help if you are high centered.
I have been carrying a ****** block, extra strap and a clevis or 2 for about 1 year now. Thankfully never had to use it.
Old Mar 31, 2016 | 08:49 PM
  #29
jgar's Avatar
Moose, this is when I winched out 1eeps BIL. We knew the ice was thin and all of us made multiple passes. Tony wasnt going fast enough!
Attached Thumbnails Winching-10150659_4189822721587_7462471432379926618_n.jpg   Winching-10155625_4189813321352_8024984717323124028_n.jpg
Old Apr 1, 2016 | 12:26 AM
  #30
greg74's Avatar
I have owned another quad, also a Grizzly 660 that had a winch. I used it sparingly but it did get me out of a couple tough spots. Maybe I need to get some accessories to go with my current winch to help if I really get stuck(****** block, I do carry a tow strap with me so got that covered, I have a 2nd one I could throw under my seat too). I don't go looking for the deepest mudholes. But sometimes you can't avoid all the mud. Ironically, I haven't had the need to use my winch since I've had it.
