Carburetor help
Old Jul 12, 2016 | 07:38 PM
Cody.vandyke's Avatar
Default Carburetor help
Ok, to start I'm new here and new to atv's in general. I recently acquired a 1997 Yamaha big bear 350 (yfm350fwbj) and when I first put fuel in it, it started pouring out of the over flow on the carb. I completely rebuilt the carb and now it doesn't leak while riding,as far as I can tell, but when sitting if the feul switch on the tank is on it slowly drips out of the overflow.
What should my next step be to fixing this? Could it be as simple as setting the float a little lower?
Any help is appreciated!
Old Jul 13, 2016 | 09:38 AM
Zrock's Avatar
Super Quad Patrol
Sounds like the float is out of adjustment
Old Jul 13, 2016 | 05:45 PM
Kymco 450i's Avatar
Exact float settings should have been included in your carb rebuild kit, they are fussy and need to be set precisely. Leaking fuel can be a real danger on a hot motor.
Old Jul 13, 2016 | 07:40 PM
They were not, and I was told the setting 'should' be 13mm (.51) is this correct? I can't find any more info anywhere
Old Jul 14, 2016 | 02:48 AM
This is supposed from a guy that has the Big Bear 350 manual.
"Valve clearance is
Intake .06 ~.10mm (.003 ~ .004")
Exhaust .16 ~ 20mm (.006" ~.007")
float level is usually 12.5-13mm however I prefer 11.5 mm and not shim the needle."
As far as instructions in carb kits,I don't think I've ever seen instructions in any carb repair kit I've ever used.I guess most places that make the kits expect you to already know or have access to a manual for this info.
Old Jul 14, 2016 | 08:36 PM
Kymco 450i's Avatar
As far as instructions in carb kits,I don't think I've ever seen instructions in any carb repair kit I've ever used.I guess most places that make the kits expect you to already know or have access to a manual for this info.[/QUOTE]
Really ??? In the past I have only used the "Uni" brand carb kits with great success and they always came with very detailed instructions and pictures on setting up your carb. Are they getting cheaper now?
hunter56
Mar 11, 2016 02:43 PM
u09692
Feb 28, 2016 12:01 PM
Kymco 450i
Feb 11, 2016 09:56 PM
kahoona
Sep 9, 2000 01:27 PM
robo
Aug 18, 2000 12:31 PM
