92 suzuki lt230e not starting now
I had to put a new gear shift switch and arm for the shift lever on and has always run like a champ, but not starter won't even try to turn. What I do wrong? Did I miss doing something? Maybe timing off no? When I bypass starter it tries to turn but doest sound right. If u give a little gas the noise gets worse. Also chain is really loose have a new one but tension bolts don't seem to give any tension. Could chain be issue or timing and chain m? This is my first quad so I'm not mechanically challenged but I am for a quad.
scottaruth
May 11, 2020 06:58 PM
KG_97xplorer
Jan 11, 2016 12:44 PM
