Klf fuel pump wiring
Old Sep 4, 2017 | 09:09 PM
Dan Monzo's Avatar
Default Klf fuel pump wiring
Hey hopefully I can find some guidance here. I just bought a 1985 klf 185. I am currently trying to replace the missing fuel pump. My issue is there doesn't seem to be any power providing wire near where the fuel pump would be mounted. The power from the pump is blue. The only two avaible wires are black and white. After trying those to see if it works. I then ran some extra wiring from the battery to the pump. Doing so made the pump work but because it was direct it can not shut off. Does anyone know where I connect the positive charge to the pump or where I need to run a secondary wire else where? There seems to be no diagram explaining how exactly the fuel pump can be installed. Thank you
