Polaris sportsman
Old Sep 5, 2017 | 10:12 PM
Keg2159's Avatar
Default Polaris sportsman
I have a 2000 335 polaris sportsman idles fine give it gas and dies out but you can play with it long enough and be able to rev it on up also broke drive belt and replaced with new one but now it goes way slower than it did before any ideas please help I'm lost
Old Sep 6, 2017 | 08:47 AM
Part of the problem could be carb related. If you tear a carb apart don't just clean old parts especially a needle and seat.You can get a good kit for the price of an oem needle and seat.POLARIS SPORTSMAN 335 CARBURETOR CARB REPAIR REBUILD KIT 1999 2000 NEW SEALED | eBay On the belt was it an oem 3211077? If not could be part of the problem on speed or could be belt fragments or belt dust in the clutches need to be blown out or the rear clutch buttons could be worn down. Item #17 in the parts break down. One other thing I'd do is pull the black wire from the reverse limiter module.
Attached Thumbnails Polaris sportsman-67ca708db7f1f46fae475ec16b4bed728fa62649.png
Old Sep 7, 2017 | 09:03 PM
Keg2159's Avatar
Hey there was a piece of old belt stuck under the weight in clutch I mentioned to get out but forgot could that be my speed problem and belt came from polaris dealer
Old Sep 8, 2017 | 05:56 AM
Any pieces of belt or dust can affect drive or driven clutch operation. Blow out the dust in an open area as it will be a lot. Open the rear clutch and use an air nozzle in the cracks. Wear a dust mask or hold your breath... If that doesn't solve the problem remember the other things I mentioned.
