Sunl ATV
Old Apr 15, 2008 | 03:12 PM
jewels21's Avatar
Default Sunl ATV
Does anyone have an idea how to get a hold of the company that makes them? my son has has it less than a year and now it is leaking gas, our local atv dealership can't fix it, thay don't have the parts for it. Half the time it doesn't work, it seems cheap. Julie-CT.
Old Apr 15, 2008 | 03:28 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default Suni ATV
Welcome to the forums Jewels21.
Not sure if you might mean Sunl instead of Suni.
Here's Sunl's website. Hope that helps you out some. Where is the gas leaking from?
Old Apr 15, 2008 | 03:56 PM
jewels21's Avatar
Default Suni ATV
Sorry, i did mean Sunl, it is leaking from the gas line, there is a puddle when we fill it up, thanks for the website, Julie
Old Apr 15, 2008 | 04:07 PM
Supersock
Hired Gun!
Default Sunl ATV
You're welcome.
If it's leaking from the tank, I'd think the only things it could be would be a crack in the tank, a leaking fuel line or a bad petcock valve. The problem with a lot of places that sell these is, they have no clue on how to repair them.
What model does he have? If this needs to be moved to another section that can help more, I can do that for you.
Old Apr 15, 2008 | 04:12 PM
sflarider's Avatar
Default Sunl ATV
The Sunls come with crap fuel lines. I would go over all the fuel lines to see if there is any cracksor rips. If there is, go
to any parts store and get some clear lines for it. Should be 3/8 line.
If there is no cracks in the lines, check the line that goes into the bottom of the tank. I had to replace the one on mine within the first few days. I went ahead and replaced all the lines with clear 3/8.
Another thing you can check, is the petcock as Scooter has said. Those things get clogged up something fierce. The pressure builds up, and eventually causes the petcock to form cracks, andf limiting the amount of fuel to the carb
Old Apr 15, 2008 | 09:56 PM
jewels21's Avatar
Default Suni ATV
I think it is a 7 sunx110acx, it is small, i think the maximim weight on it is 220lbs. Julie
Bigredjeep
Apr 10, 2020 02:55 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
Mobyguzzer
Apr 28, 2006 11:25 PM
