fishing poles
Anybody transport fishing poles in their utv/atv? Is there a better way than handing them to your passenger and saying, "Here. Hold these."?????
Does anybody make a rack?
i strap mine down on the back rack pointing forward with my tackle box then stick the tip of the rod under my front rack. I position it close enough to me on my brute so i can wrap my leg over top of it just to make sure it doesnt bounce free.
Hard to tell by the pic. How long is it? You put the rod inside?
I thought about building a rack to mount to the front of the bed and the poles stick straight up..but the first time I go under a tree..... :\
Its made from PVC plumbing pipe with a sealed glued cap on one end and a threaded screw end on the other so the length and dia is up to you and your rod. We just bungie the tube on the rack. I had other ATV run over it once and the rod was still OK. LOL
One stroll down a building supply store's plumbing section and you will figger in out easy. Don't forget to buy the PVC glue for the ends.
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
