Help With Forum Software! A Place to get Help with the Forum.
WYSIWYG Editor problem
Old Oct 19, 2002 | 04:39 PM
MuddHound's Avatar
Default WYSIWYG Editor problem
I am having a big problem with the WYSIWYG Editor, when I try to start a topic or reply to one my "Message Text" section is only about an inch wide at the left side of my screen. The only icon at the top of the "Message Text" block is the help icon.
Is everyone that's using the WYSIWYG Editor experiencing this problem or is it just me? It worked perfectly before the spell check update and then worked for a few more posts then it did this.
Old Oct 19, 2002 | 08:16 PM
YFZRacer's Avatar
i had the exact same problem so i switched back to regular
Old Oct 20, 2002 | 06:19 PM
YFZRacer's Avatar
it also screwed up my fonts so i had to system restore so i didn't have it
for example where you lived when really narrow and made it blurry and it was happening on other sites to
Old Oct 20, 2002 | 08:40 PM
Fango's Avatar
I have the same problem with the small screen on the side too??!!! Hopefully this is just a bug that can be worked out.
Old Oct 22, 2002 | 01:35 AM
armoks's Avatar
Mine too!! this little screen is driving me nutz!
Old Oct 22, 2002 | 11:40 PM
YFZRacer's Avatar
switch back to normal
Old Oct 23, 2002 | 12:27 AM
MuddHound's Avatar
I just decided to test to see if the WYSIWYG Editor was fixed yet. Well I switched over to it and started to reply and found the same small screen, well I figured it wouldn't hurt to click on help, when I tried to click the help icon I got the following system message:
You are using an unsupported browser.
You should use Internet Explorer or a browser that works with the Java 2 Plugin (such as Netscape 6.2 and up) to get all the functionality.
I find this truly odd since I'm running IE 6.0.
Hope this info helps somehow.
Old Oct 23, 2002 | 12:41 AM
dbeck's Avatar
It's funny because I thought I was the only person that had run into the problem and I've been programming for the last 3 hours to fix it. I no sooner got it fixed and I saw your posts! Sorry!
Its fixed now. Please try it again.
Old Oct 23, 2002 | 12:58 AM
MuddHound's Avatar
Originally posted by: dbeck
It's funny because I thought I was the only person that had run into the problem and I've been programming for the last 3 hours to fix it. I no sooner got it fixed and I saw your posts! Sorry!Its fixed now. Please try it again.
Thanks dbeck, you da man!!!
Old Oct 23, 2002 | 01:36 AM
armoks's Avatar
Thanks dbeck. As always, there to keep us on our feet[img]i/expressions/face-icon-small-wink.gif[/img]
