Jetting Problems w/ 300ex
Old May 9, 2000 | 06:57 PM
AdrenalinJunkie's Avatar
I have a Graydon Proline pipe/silencer and i have 10 1" holes in my airbox lid...the problem is that it is starting to heat up a lot and when i give it gas at high revs it skips...so i jetted up 2 notches and it bogged out BAD when i touched the gas but didnt skip at high revs. i went down a notch and it still did it. so i left it the same with the small skip. Any ideas on what i should do?
Old May 9, 2000 | 07:32 PM
Y2K300EX's Avatar
What do you mean, jetted up 2 notches? On the needle, or the main jet. If it is skiping at high rpm's then you might need to raise the main jet. I am not completly sure so don't go chaging things until someone that has more knowledge resonds also.
Old May 9, 2000 | 09:45 PM
hot_shoe_cv's Avatar
I too am a little confused by your explanation. Exactly what did you do? I'm not sure what you mean by "notches". Over heating can be caused by a lean condition & the problems get much worse with continued use. Put your jet needle in the 3rd position (center slot). Then install a main jet two sizes fatter than you now run.Put in a new plug and test ride at 3/4 to full throttle for at least 1/2 mile.
Cut your engine & pull & read your plug for color. If it shows tan or light brown and you had no cutting out at full throttle you have the right air/fuel mix
Old May 9, 2000 | 10:51 PM
hondatrx300ex's Avatar
so this is the same do on *********? I'm 300ex_in_tx or trx300ex. later
Old May 9, 2000 | 11:20 PM
ok...thanks a lot for the help..i was misinformed.someone said to move the needle up 2 notches and do nothing with the main..so i should go up 2 with the main. what about the pilot?
Old May 9, 2000 | 11:22 PM
BY the way (hondatrx300ex) did you ever find a Graydon Proline pipe?
Old May 10, 2000 | 08:27 AM
whats the deal they won't let you say ********* on hear? nah I think I've changed my mind cause I've heard the graydon proline pipe doesn't add hardly any top end. I'm gonna be doing some mx racing and need quite a bit of top end. I'm looking at the supetrapp ids2 or white bros e-series.anyways see ya
Old May 10, 2000 | 06:59 PM
I race mx and I get pretty good top end. I can do around 60-65 mph flat out. If you wanna race mx you are gonna need mid and low more than top anyway arent you?
Old May 10, 2000 | 11:01 PM
well not the tracks around hear they are big long and fast! you just gotta haul to do the jumps. thats why I want some top end. today I rode a banshee for the first time. I like the top end of it but I got tired real easy cause it doesn't haddle quite as good as my 300ex. anyways I want a pipe that adds alot of top without taking any of the bottom away. later man
Old May 11, 2000 | 06:06 PM
thats the opposite of most of the tracks i ride....they are quick and tight....jump right after jump. Yeah i agree with ya about the banshees too...
