300ex axle....HElp
Old Jun 19, 2003 | 10:08 PM
Pineway's Avatar
Default 300ex axle
I am trying to get my 300 axle off. I loosened the axle bolt and it slides back and forth but wont slide off. i was wondering if anyone could help me with this problem.
Thanks.
Old Jun 20, 2003 | 10:48 AM
Semms40oz's Avatar
Default 300ex axle....HElp
Before you can remove the nut and thread assembly you have to remove the clip that holds it on.
click here
It item number 13 on the schematic
Old Jun 20, 2003 | 11:42 AM
Pineway's Avatar
the clip is allready off and the nut is lose but it still wont slide off.
Old Jun 20, 2003 | 11:55 AM
Semms40oz's Avatar
If the clip is off it should slide right out, what is it getting stuck on? you have to slide the nut/thread assembly off before removing the axle. i'm going to list the steps and use the numbers from the schematic i posted earlier:
1.remove part 13 (clip)
2.slide off parts 6, 9, and 10 (nut/thread assembly)
3.slide off part 4 and 5 (rotor and hub)
4. slide out the axle form the oppisite side
I wasn't sure if you were having trouble getting the nut/thread assembly off or just trying to remove the axle with the nuts loose. so i just listed all the steps in case.
Old Jun 20, 2003 | 12:34 PM
Pineway's Avatar
i have the clip out, and the axle nut is lose and slides back and forth, but wont slide past where the clip originally was even though its off. I cant figure it out.
Old Jun 20, 2003 | 01:16 PM
Semms40oz's Avatar
inspect the axle for any burrs or rough edges, also look at the end of the nut. you might have hit a rock or something with the axle or nut and put just enough of a burr in it to prevent it from easily sliding off. if you find a burr you'll have to use a dremel or a grinder to remove it.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
