What is this? 300ex question again
Old Jul 9, 2003 | 01:58 PM
TheQuadSport230's Avatar
Default What is this? 300ex question again
When checking thing about My CDI BOX, I found that there were 2 black box. I figured out that which one was the cdi box. The other is called the INHIBITOR UNIT. REVERSE. I checked this on Service Honda
Look in the Wire Harness category, Item #8. What is this INHIBITOR UNIT. REVERSE. used for?
Thanks a lot
Old Jul 9, 2003 | 03:12 PM
AlkyBurninX's Avatar
It is the reverse rev limit. It has the green plugs on it vs. the CDI has the clear. They use the same type of plug though.
Old Jul 9, 2003 | 03:19 PM
Yes it's the one with green plug. So It's the reverse rev limiter. Can it be damaged?
Old Jul 10, 2003 | 02:18 AM
I have never seen one go bad. Are you having trouble with it? If so, it is probably your coil. I have seen a few go bad on 300ex's. Do you have a service manual?
Old Jul 10, 2003 | 12:33 PM
No I don't, it's because i'M cheking eveyr electrical components to find my problem
Old Jul 11, 2003 | 04:42 PM
Take your coil off. The backside probably looks melted. Like I said, I have seen 300ex's with bad coils. They short out and melt. The secondaries is actually what go bad so if you measure across the prongs, it will read good. Measure the resistance from the plug wire to each prong. This is usually what is shorted.
Old Jul 11, 2003 | 05:12 PM
What should be the normal resistance?
Old Jul 11, 2003 | 08:12 PM
Ok, I checked the coil. .I checked the resistance. I don't really how a multimeter works [img]i/expressions/face-icon-small-confused.gif[/img]
because I'm 15. Here what happened. When I put it on 200 Ohms, It give me a big one. same thing on 2K ohms. When I put it on 200K Ohms, I read a 3. On 20M Ohms, I read a 0. What's up with that coil? When I use the conductivity beeping mode (beeps when it conducts), It doesn't do like normally ( Read 0 and beeps), it reads 1386-1387 and it doesn't beeps. normally when it don't conduct, it just read a big 1. What's UP? Thanks
Old Jul 12, 2003 | 01:01 PM
Anybody can tell me if my coil is still good? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 12, 2003 | 02:24 PM
HondaMan400EX's Avatar
Hey, TheQuadSport...do you have any pictures of your 300EX? I would like to see it..I may be buying a 1996 300EX with a 396 big bore kit with some mods and I was just wondering what they look like...or do they look the same as the others...just a different color plastic?
bigred20653
Oct 2, 2015 10:05 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
