Help won't start!
Old Jul 20, 2003 | 01:55 AM
devildog23's Avatar
Default Help won't start!
When I had to get it pulled back to the spot I tried to pop the clutch along the way and it did not work
Old Jul 20, 2003 | 01:59 AM
TractorPacker's Avatar
Do you have a balloon?
Before you beat your brains any further take the center plug out of the stator cover. That is a10mm allen wrench, in there is abolt on the end of the crankshaft. Put your 17mm socket on it and make sure you didn't sieze the engine.
Old Jul 20, 2003 | 02:24 AM
devildog23's Avatar
I dont know what to do
Old Jul 20, 2003 | 02:25 AM
devildog23's Avatar
Give me some time I will try that I will let you know how it turns out
Old Jul 20, 2003 | 02:15 PM
  #15
Hondaracer3's Avatar
You can stick a screwdriver in between the two bolts on top of the cillinoid and jump start it untill you get a new one if thats the problem.that was what was wrong with mine. make sure the screwdriver is touching the two bolts though.
Old Jul 28, 2003 | 12:32 PM
  #16
crispy's Avatar
yeah, what hondaracer said. try to jump start it with a screw driver, that should work.
Old Aug 3, 2003 | 11:33 PM
  #17
HondaATC110RULES's Avatar
Im not sure where the wire for the neutral light goes in the motor on your bike, but it is probably on the right side of the motor on the bottom.Make sure the wire is pluged into the side of the motor.The neutral wire came unpluged on my 300 fourtrax and it did the same thing.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
