Recon cold blooded!
Old May 22, 2000 | 04:47 PM
Nocando's Avatar
I have a brand new 2000 Recon and the damn thing won't stay runnin till warmed up. Choke seems to do nothing. Checked the choke cable to ensure its pulling up the choke and it does. I have to keep thumbing the darn throttle to keep it running. Dealer said this is normal they are cold blooded. I have four quads and it isn't normal on them. Any answers would be helpful. This is only a week old.
Nocando
Old May 22, 2000 | 05:01 PM
Hondapride's Avatar
Yeh Thats one of the downfalls of the recon, It is hard to start but once its warmed up it starts with minimal effort.
I have a 1998 recon and have noticed the same thing. What I did was turned the idle screw on the carb up a little bit so that it idles a little higher. Dont make it idle so high that it is difficult to shift because thats hard on the transmission. I hope this helps, mine idles fine about 30 seconds after the first start-up of the day, and then its fine.
Hope you dont have too much more trouble, if you have anymore questions about the bike just ask.
Old May 22, 2000 | 05:04 PM
snowshark's Avatar
I can relate. Ours is the same way its 2 months old.
What we do is once it starts you have to sit there & give it gas for a minute or two.
The dealer told us the same thing when we took it in for its intial 20 hour check up.
Old May 22, 2000 | 05:09 PM
Nocando's Avatar
Thanks guys it's something I can deal with, I just wanted to know if it was normal.
Nocando
1989 LT500R (Mine)
2000 Recon (Wife and Oldest son)
1989 LT80 (Youngest son)
2000 Trail Boss 325(Brothers)
Old May 22, 2000 | 09:59 PM
trac's Avatar
nocando, I DON,T KNOW IF THIS WILL HELP BUT AT LEAST TRY IT .I HAD SAME PROBLEM W/MY 450. I ONLY RUN AMOCO ULTIMATE BUT I TALK TO FRIEND AND HE SUGGESTED NOT RUNNING HIGH OCTANE HE SAID TO USE MID GRADE. ANYWAY I DON,T THAT PROBLEM SINCE I CHANGED GRADES. HOPE IT HELPS YOU!!! TRAC
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
