lug nuts & aluminum wheels
Old May 25, 2000 | 08:37 AM
chadwick's Avatar
I just received the aluminum wheels I order and put them on my Honda, the problem is i did'nt order lug nuts because I thought my stock ones would work fine. When I put the lug nuts on the studs they only threaded halfway down the nuts. The aluminum wheels are thicker in the center than my stock wheels. My question is if anyone has encountered this and what was your solution, or is it necessary to purchase new lug nuts?
Old May 25, 2000 | 12:28 PM
Guest
Guest
Posts: n/a
Check to see if the new rims are tapered or flat where the lugs go on. If it is flat make sure that you are not trying to put tapered lugs on them. If you have tapered lugs and flat rims, you will need to get new flat lugs. Dura-Blu has the billet alum. flat lugs.
Old May 25, 2000 | 09:08 PM
chadwick's Avatar
Thanks, I just received my rear wheels and tires today and they came with flat lug nuts. The front wheels came with no lug nuts, I'm calling to see why now.
Old May 25, 2000 | 09:42 PM
426ex's Avatar
take the nut and turn it around and there you have it a flat nut. i had to do the same thing.
Old May 25, 2000 | 10:48 PM
chadwick's Avatar
I was going to try that but my stock lug nuts have a flanged end that will not allow a socket wrench to be placed over it.
Old May 25, 2000 | 11:31 PM
tprender's Avatar
If you have a 250r, 300ex or a 400ex just turn the tapered lug nut around and they will work just find. The only problem that you will have is that the hole on the rim will get smaller after you tighten the nut down a few times. We have to drill out the hole on the rim every so often. This can be stopped by using washers between the rim and the lug nut. If you don't drill out the hole, you can not get the rim off of the axle quickly. This has happened to use during a race when we had to change a flat and it was no fun.
Old May 26, 2000 | 11:51 PM
b(250rman)'s Avatar
when I put my itp .190's all the way around on my 250r I simply turn the lug nut around and put a washer on it. and torque it to 20 foot pounds. same thing when I put the rear wheels on my 300ex.
meddy0388
Sep 9, 2015 06:41 AM
bmark0610
Sep 7, 2015 09:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
