2002 honda 450 es odometer
hi my 450 had 550 miles on it . i went to turn it on and it showed that it had 33450 miles on it and the hour meter showed 3350 hours on it . is there a way to reset this? i got a buddy that has the same problem on his, is this a problem that honda should be recalling thanks bud
I really don't know if you can reset it. Did you try disconnecting the battery? If you don't get an answer here then you could try calling Honda and they MIGHT do something even though your warranty is up. Do you have an extended warranty? (310)532-9811 It doesn't hurt to ask.
