difference between 300ex and 400ex
Old Aug 19, 2003 | 09:09 PM
dirtrider138's Avatar
Default difference between 300ex and 400ex
Old Aug 19, 2003 | 09:40 PM
sickmojave's Avatar
yeap there is a difference [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 19, 2003 | 09:42 PM
rockrider's Avatar
Hondamotorcycles.com
Old Aug 19, 2003 | 09:44 PM
what kind of diference? not just cc.
Old Aug 19, 2003 | 09:49 PM
sickmojave's Avatar
well lets see
300ex
ENGINE
Engine Type 282cc air-cooled SOHC single-cylinder four-stroke
Bore and Stroke 74.0mm x 65.5mm
Carburetion 32mm piston-valve with accelerator pump
Ignition Solid-state CD with electronic advance
Starter Electric
DRIVE TRAIN
Clutch Manual
Transmission Five-speed with reverse
Driveline O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone with dual hydraulic shocks, five-position spring-preload adjustability; 6.7-inch travel
Rear Suspension Swingarm with single shock, five-position spring-preload adjustability; 7.9-inch travel
Front Brakes Dual hydraulic discs
Rear Brake Single hydraulic disc
Front Tires 22 x 7-10 knobby
Rear Tires 22 x 10-9 knobby
DIMENSIONS
Length 67.7 inches
Width 43.5 inches
Height 42.7 inches
Wheelbase 45.3 inches
Seat Height 30.3 inches
Ground Clearance 4.9 inches
Turning Radius 10.2 feet
Dry Weight 377.0 pounds
Fuel Capacity 2.2 gallons, including 0.5-gallon reserve
OTHER
Available Colors Red, Yellow
Model ID TRX300EX
Old Aug 19, 2003 | 09:51 PM
sickmojave's Avatar
400 ex
ENGINE
Engine Type 397cc RFVC air-cooled dry-sump single-cylinder four-stroke
Bore and Stroke 85.0mm x 70.0mm
Carburetion 38mm piston-valve with accelerator pump
Starter Electric
DRIVE TRAIN
Clutch Manual
Front Suspension Independent double-wishbone with Showa shocks, five-position spring-preload adjustability; 8.2-inch travel
Rear Suspension Pro-Link fully adjustable single Showa shock; 9.1-inch travel
Front Brakes Dual hydraulic 174mm discs
Rear Brake Single 220mm disc
Front Tires 22 x 7-10 knobby radial
Rear Tires 20 x 10-9 knobby radial
DIMENSIONS
Length 72.2 inches
Width 45.3 inches
Height 43.7 inches
Wheelbase 48.4 inches
Seat Height 31.9 inches
Ground Clearance 4.3 inches
Turning Radius 10.5 feet
Dry Weight 375.0 pounds
Fuel Capacity 2.6 gallons, including 0.4-gallon reserve
OTHER
Model ID TRX400EX
Old Aug 19, 2003 | 10:00 PM
thanks
Old Aug 19, 2003 | 10:14 PM
roosthrower's Avatar
the 400ex puts out almost twice the power of a 300ex and it has a better suspension. top speed is 53 for the 300 and 65-68 on the 400.
Old Aug 19, 2003 | 11:13 PM
which one has the bestvbottom end
fredrikrosen
Sep 28, 2015 09:58 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
