Carburetor 101
Old Aug 29, 2003 | 04:15 PM
TheQuadSport230's Avatar
Default Carburetor 101
I was wanting to know some things about the components of a carburetor. I was wondering what was the purpose of the main jet, pilot jet and needle. Thanks
Old Aug 29, 2003 | 04:23 PM
sickmojave's Avatar
the pilot jet is for low end up 1/4 throttle
the main jet is for wide open throttle
and the needle is for everything in between
Old Aug 29, 2003 | 05:39 PM
HA2's Avatar
HA2
dismantling shines some lights on what does what. make sure you either know what is what or have a maual before u dive in head first, but it does help knowing what's going on in there. [img]i/expressions/face-icon-small-smile.gif[/img] bring your imagination.
Old Aug 29, 2003 | 08:41 PM
PilotSniper's Avatar
I use this page to refresh my memory whenever I'm adjusting my carburetor...
http://www.yellowdogracing.com/techstuff.htm
Hope it helps.
Good luck!
Old Aug 29, 2003 | 08:56 PM
HA2's Avatar
HA2
i dont know if this helps, but i keep my old spark plugs, date the bag, and mods i had on the bike at the time.
Old Aug 29, 2003 | 11:56 PM
Thanks PiloTSniper. But what his the needle jet? I knew about the main jet and the pilot jet but the needle jet?
Old Aug 30, 2003 | 12:07 AM
Originally posted by: TheQuadSport230
Thanks PiloTSniper. But what is the needle jet? I knew about the main jet and the pilot jet but the needle jet?
You don't really need to mess with the needle jet. That's the "cylindrical brass passage located directly above the main jet". It's the part that the jet needle (the needle on the bottom of the slide with the 5 c-clip positions) goes into before getting to the main jet. Pretend you never read about it and it will all get easier to understand. [img]i/expressions/face-icon-small-smile.gif[/img]
Good luck!
Old Aug 30, 2003 | 12:40 AM
Hehe, I've got many things to learn with a carb. I thought that the "cylindrical brass passage located directly above the main jet" was the pilot jet [img]i/expressions/face-icon-small-blush.gif[/img] . In that case, where is the pilot jet?
Old Aug 30, 2003 | 03:59 PM
It's located in another area of the carburetor (dependent upon the carb), accessible by removing the float bowl. It sounds like you would be better off jumping in head first and opening up your carburetor. This way, you could see what you're dealing with. Get yourself a rebuild kit and go to town on it. This will definitely get you on your way. It's not difficult! Just be patient, follow directions and don't strip anything! Some of these carbs have "butter screws", named this way because they melt quickly if you treat them the wrong way.
Here's a shot of my rebuild on a Keihin carb for my FL250 Odyssey...
Carburetor Rebuild
By the way, the pilot jet in the pic is the lower one.
Good luck!
Old Aug 30, 2003 | 11:17 PM
Thanks again pilotsniper [img]i/expressions/face-icon-small-smile.gif[/img]
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
