so honda fans, are you dissappointed yet?
#51
Originally posted by: fivel250rman
I'm interested to see the power delivery.The Honda has a 42 mm carb the Yamaha has a 39mm.The way thay have lowered the cc's in both are different.Yamaha has shortened the stroke,Honda shortened the stroke slightly and also has a slightly smaller bore.These two differances could make the two engines perform quite differently.Can't wait to line them up.
#52
my .02
The Honda is $400 cheaper than the Yamaha. The HRC performance kit cost $300 if it doesn't come with a piston you can by a 12:1 piston like the dirtbike for under $100. With that said and done you would be at msrp for the Yamaha and have a faster honda. I know the Yamaha has more potential but <U>for me</U> anywhere in the mid 40's and up for hp is more than enough especially if I can get there or higher with the above modifications.
#53
btw,
I would be insulted if Honda wanted more for this bike than Yamaha wanted for the YFZ but since it's detuned more and they want less for it I'm not insulted at all. I don't mind the kickstart only thing.
#54
the kit supposedly comes with a cam, new internal parts for the exhuast, carb kit and I think air filter. The exhuast is already fairly light as opposed to the big heavy black one that comes with most quads so if you get new packing and an insert it would probably be pretty good.
#55
#57
Originally posted by: 250R4LIFE
The carb kit is just some jets,To rejet with the other mods. And that's pretty bad if they already have a fairly light pipe & they still couldn't get the bike under 350 lbs. The YFZ comes with a big heavy black pipe. So When you get a aftermarket pipe, your probably shaving a couple of pounds. And everything Ridley said was right. And who knows how much the smaller exhaust valve are going to effect it.
Originally posted by: DirtDigglerthe kit supposedly comes with a cam, new internal parts for the exhuast, carb kit and I think air filter. The exhuast is already fairly light as opposed to the big heavy black one that comes with most quads so if you get new packing and an insert it would probably be pretty good.
#58
250rforlife,you are absolutely correct.The stroke was lenghtened.Thanks for catching that.I am beating myself with the keyboard as I speak.
04 CRF 450 bore 96.0 mm stroke 62.1mm
04 TRX 450R bore 94.0 mm stroke 64.8mm
400H0
10
Aug 20, 2015 07:34 PM
