250r frame reinforcement
Old Sep 28, 2003 | 07:00 PM
loudpipes's Avatar
Default 250r frame reinforcement
I am in the process of building a 250r from the ground up. As of now I have an 87 engine and a 89 frame on the way. Is there any spots on the frame that are prone to cracking? I want to put some reinforcing welds while the frame is by itself so where are some spots you would recomend putting them. Also will 87 motor mounts bolt on to an 89 frame. Thanks
Old Sep 28, 2003 | 10:45 PM
Bubba297's Avatar
Definitely swingarm mounting holes are prone to cracking, rear bottom motor mount tabs,front motor mounts,and if you are really hard on it, the support for the upper steering bushing.Those were all cracked on our frame and I have seen others. Look on e-bay right now. There is a white Honda frame that has been reinforced some. That will give you a good idea for the swingarm holes. Hope this helps,Bubba
Old Sep 29, 2003 | 01:39 PM
Mike330R's Avatar
Lots of good frame info here.
Also I beleive TBR sells a kit that you can weld onto your frame.
Old Sep 29, 2003 | 04:04 PM
jaycekarl10's Avatar
I don't know if they have a "Kit" per-se but I know they do gusseting there. It couldn't hurt to ask, but even with a kit, you'll still need a person to welt it together. I've seen a couple they've done, very clean and very strong.
Old Sep 29, 2003 | 08:46 PM
Ask and you shall recieve!
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
