250xr
Old Jun 15, 2000 | 01:35 PM
JumpKing's Avatar
I am taking on a new project quad, I will be puting a 250r motor in a 250x frame. Does any one know wich frame is better. Has anyone every done this before.
Old Jun 15, 2000 | 02:35 PM
Brad_L's Avatar
Jumpking,
Just out of curiosity, why are you going to attempt this swap?
A much more desired swap is to install the 250x motor in a 250r chassis. The reason being is because the 250r chassis is much more friendly to ride in the real rough stuff. The 250r chassis is longer, wider and has more suspension travel then the 250x chassis.
Old Jun 15, 2000 | 02:55 PM
JumpKing's Avatar
I thought that the x frame is better. Is it the other way around the r frame is better.
Old Jun 15, 2000 | 03:07 PM
JumpKing's Avatar
so what do most people race the r frame with the r motor, or the r frame with the x motor, or the x frame with the r motor.
Old Jun 15, 2000 | 03:53 PM
Y2K300EX's Avatar
Most people that like 2 strokes like the R motor in the R frame. If they like 4 strokes they like a X motor in the R frame because it has better geometry, and more suspension travel.
Old Jun 15, 2000 | 04:27 PM
JumpKing's Avatar
I have a question were on a 250r is the most common place that it cracks or breaks. I looking at some to by and i need to know where to look at them to see were they crack but i just wanted to know were they most commnly crack or break.
Old Jun 15, 2000 | 05:10 PM
Brad_L's Avatar
Of course its best to overlook the entire frame for cracks, but in my experience the first three places I looks are around the swingarm pivot bolt, the lower motor mounts, and the steering stem hoop on top of the frame.
Old Jun 15, 2000 | 05:58 PM
JumpKing's Avatar
Is there a way to tell for sure, if a frame is a 250r frame. If you dont want to get stuck with a 250x or some other honda frame.
Old Jun 18, 2000 | 11:10 PM
JumpKing's Avatar
is there no way to tell
Old Jun 19, 2000 | 11:00 AM
WOODRIDER400's Avatar
What would the advantages be to using a 250x motor over just running a 250r motor? I have seen this done, but what kind of power would or could you get out of a 250x?
