Axle bearing carrier
Old Nov 12, 2003 | 12:51 AM
catmans300ex's Avatar
Default Axle bearing carrier
mine has a small crack in on the part where u tighten the chain. is it ok to ride like this does anyone know where i can buy a used one or really cheap one besides the 220 dollar OEM one from the honda dealers ? also how hard is it to put on thanks this is on a 300ex
Alex
Old Nov 12, 2003 | 09:03 PM
250ex's Avatar
should be ok. taking carrier out is easy. the locknut will be the hardest part. after you do it once it'll be easy from then on.
Old Nov 12, 2003 | 10:30 PM
Quadfather's Avatar
You can buy an aluminum twin row bearing carrier from just about any ATV performance shop for around $150. Check ebay, and you might find one cheaper.
Old Nov 13, 2003 | 04:29 AM
ok thanks alot guys for everthing . ill ride a little longer to se if the crack increases
Alex
Old Nov 13, 2003 | 08:37 AM
tprender's Avatar
I would be very carefull when riding. If the carrier breaks it will most liky mess up the axle also. then you will have to buy an axle and a carrier. The samll crack will last how long before it breaks???
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
jbrewster94
Sep 23, 2015 04:16 PM
1000gade
Sep 9, 2015 04:41 PM
