rubicon screeching noise
Old Nov 16, 2003 | 08:21 PM
TIC's Avatar
TIC
Default rubicon screeching noise
Its making a souind that is identical to the sound of the brakes on a car when they need replaced an very noticalbe screech when driving forward after the atv reaches the speed of 8 mph. it dont do it in rverse it dont do it under 7 or 8 mph and applying the brakes dont change the pitch of the sound or lessen it any. and it will not make the noise in revers. Iwas thinking a dragging squeeking brake, a wheel bearing getting ready to go. but why only after a certain speed> and why not in reverse?
I hope its nothing to do with clutch or the hondamatic itself, Please help if you have any ideas or suggestions. this just happend 1 hour ago, I have done no investigating.
thanks again,
Old Nov 17, 2003 | 02:43 AM
swampdonkeykiller's Avatar
sounds like a brake shoe is dragging somewhere. Or you could have a rock rubbing on a drum or between your backing plate and drum maybe.
Old Nov 17, 2003 | 08:58 AM
TIC's Avatar
TIC
I was hoping also that it would be that simple, but after digging into a little bit more, ive found that I can coast it down hill in neautral and it does not do it at all.
But when I put it in drive and go forward under pressure it makes the noise and the second i let off the throttle, and the transmissions starts to disingauge the noise will stop. I have a bad fealing it may be the hondamatic or the pump or the centrifical clutch? i dont know.
If ol tex mud is around here I sure could use his help
Old Nov 17, 2003 | 12:50 PM
now that I think about it may be a relief valve in your transmission or something pump related. Have you changed your oil recently? You may want to try that and check your filter for debris. Just an idea.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
