400EX Wont shift
Old Nov 22, 2003 | 03:29 AM
URCRAZY's Avatar
Default 400EX Wont shift
Hello, I was wondering if anybody else with a 400EX has had trouble with their shifting or gears. I was letting this chick ride mine, she was going to buy it, then everytime she was trying to shift to second it would go into neutral. I tried and could not get it to go to second unless I used a lot of force, and when I did, it would pop back to neutral when I let go of the gas. I think it might be my shifting fork, but I am not sure. The sad thing is the chick did not even say sorry or offer to help pay for it to be fixed, and backed out from buying my quad. Damn. Let me know what you think of the shifting problem. NOt the chick. LOL
Old Nov 22, 2003 | 03:54 AM
havinnoj's Avatar
I know that for banshees that if after you shift from 2nd and it pops into neutral that the dogs are messed up. I do not know about a 400ex tho. I would look into this.
Old Nov 22, 2003 | 06:46 PM
NotuRaptor2's Avatar
Sounds stupid but make sure the shifter isn't hitting the case. The stock ones bends easily. I seem it happen many times.
/jon
Old Nov 22, 2003 | 07:26 PM
420EX's Avatar
yea it could be the shifter, hopefully its not the internal shifting problem that has plagued many 400ex owners, including myself, but if it is internal, well you're in for ALOT of work, you have to disassemble the entire engine, split the cases, take out the trans and take it to your honda dealer for inspection. you usually cant tell just by looking at the transmission what the problem is and thats why you have to take it to your dealer, B&E Honda in valporaiso Indiana is chrgine me $65 for full trans inspection.
Old Nov 22, 2003 | 11:22 PM
URCRAZY's Avatar
Yes it must be internal, cause the shifter is not hitting the case, I even took the shifter off thinking that the splines were not catching, BUt nope. I just had my engine re done last winter, you would think that Honda would have seen any worn parts. I did have third gear replaced because of pitting. Maybe they did not see the shifter fork or other gears messing up. It is going to cost some money for this repair.
Thanks'
Old Nov 23, 2003 | 04:34 AM
420EX's Avatar
some is an understatement
Old Nov 23, 2003 | 03:03 PM
fastasyoucango's Avatar
I just finished fixing my 400ex for the same problem. The dogs were rounded off. I put in a new second gear on the counter shaft and a new shift fork and now it shifts great. Just got it going this morning.
Old Nov 26, 2003 | 05:25 PM
Sandrider503's Avatar
my 03 400ex did the same thing but it's not all the time I think it's kinda sh!tty my did it it's first weekend at SandLake but it does not go into neutral after i let off the gas oh by the way what are dogs
Old Jun 18, 2004 | 10:29 PM
emac's Avatar
hey my quad sounds like it is having the same problems as yours. how much did it cost to you to fix it. i am trying to do all the work myslef, if you did how hard was it?
Old Jun 18, 2004 | 10:55 PM
URCRAZY's Avatar
I had it fixed by the Honda dealer in Wassila AK. IT was the shift detent bolt or something like that, that came loose. They did not have to spilt the case, I think they just took the one side off. I am not sure. It did not cost much, something like 2hrs of Labor. Can not remember the exact cost.
Hope this helps.
