My starter clicks?!?!?
When i go to start my 2001 300ex all i hear is a clicking noise everytime i push the start button from the starter.......i have tried charging the battery but nothing...my light is full brightness so i am sure my battery isnt dead...one time it did kik over and was trying to start but then it started to die out so i stopped....then all i got was clicking....anyone know whats wrong? could the cold possibly do it?? this isn't the first time either... i usualy jump around on it in place and sumtimes it will kik over...
Could still be a defective battery. Put a voltmeter on it and watch how much it drops when you press the starter button. If there s a defective cell, lights may still look bright but will not start (not enough ampacity).
Could be a loose/corroded connection on the battery, ground, or starter.
Happened to me a couple of times too. Turned out the battery connection wasn't all the way tight. Check that first. Also make sure that the terminals are clean and that you're getting a good connection. If that doesn't work then you will have to do some investigating. If the battery is old it would still run your lights most likely, but may not have enough juice to run the starter and if it has a bad cell it won't charge either. Try using another battery and if that doesn't work then you know you have a problem with the starter.
yeah-- with either a rubber mallet or a peice of wood, tap lieghtly on the starter body as the solenoid rushes may be getting hung up. is this is the case then a solenoid rebuild is lekely in order, not a big deal really....
yes that could be the problem...i was noticing if i would kick it with my foot it would sometimes kik over....how much would something like thats cost to get fixed?? Thanks every1 very big help...
hahah well guess what guys....i just bought a new battery and boom first try it started right up in 23 degree weather.... i still don't understand why the start was clicking but hopefully the battery did it....Thanks every1...
