400ex doesn't like to run
oneten's problem is it doesn't idle AT ALL (i am his friend) it runs fine till you let off the gas, i am guessing that it is not jetted for cold weather
pizza914- hey are you going this weekend?? we might be at florence (depending on weather) look for a black 400ex
kc
kc
for easier starting, pump the thumb throttle lever a few times, theres an excellerator pump on the carburetor that shoots a small jet of gasoline into the intake, kinda like a primer on a lawnmower.
Since the idle circuit is on the slow/pilot jet that would be something to think about increasing in size, but I would try richening up the air/fuel screw first to see if that solves the problem.
Hey Dasandbomb, I kinda doubt I'm heading down this Weekend. If it was going to be dry & the roads were clear that would be fine. I could probably find a few guys to head up if the weather was ok! Give me a buzz if you guys are heading up. My name is Jamie Rust & I grew up in south Corvallis. If you guys ever get up Monmouth way I own Main St. Pizza here. Stop in for some chow & to say hello! Heck maybe we know each other from years back. I moved to Monmouth 8 years ago. Here is my cell 971-388-4674 or my store # 503-838-4040
#15
try turning the fuel skrew out to 3 turns from lightly seated given you have the stock pilot jet in. also, raise your idle if it is too low. the idle adjustment is on the left side of the carb when sitting on the bike. it is a silver skrew you can adjust with a flat blade skrew driver or your hand.
#16
Also, if you expect it to start when it's very cold, having some good fresh gas in the CARBURATOR makes it alot easier. There is such a small amount stored in the carb, it gets "thick" pretty fast, just a few weeks. I have found what's in the fuel tank is in much better shape than what got left in the carb last time you rode it. So if it's been sitting for awhile, turn your gas off, and drain the carb via the screw on the very bottem of the float bowl before you even try to start it. That thick old gas can foul your spark plug too, no matter how new it is.
#18
Originally posted by: oneten
i just got a 2003 400ex for christmas and it ran fine until the cold weather came. it has a K&N air filter and an LRD full exhaust and im pretty sure it has a jet kit. is there something wrong with my motor or does it just not like cold weather? thanks
mine is running fine in this weather
#20
and also what 420EX said. (but it can also result in a flloded motor if you pump too much)
It defenitely sounds like you need more fuel on the idle. (and maybe more air)(idle adjustment)
It could also be a clogged pilot jet.
It wouldnt hurt to adjust the valves either (you might be pleasantly surprised).
jrooker6
Apr 23, 2016 07:36 PM
