Why does Foremen es run so rich
Old Jan 10, 2004 | 10:26 AM
Cobra14's Avatar
Default Why does Foremen es run so rich
every 3-6 week we have to replace the plug when we take it out its black. And the bike always stinks like heavy gas
Old Jan 10, 2004 | 11:08 AM
Chilly's Avatar
My 400 was the same when I got it, I just leaned out the idle mixture a little, the heavy gas smell is gone now, but I haven't checked the plug recently. Make sure it's the right heat range.
Old Jan 10, 2004 | 01:46 PM
hondabuster's Avatar
Mine was running a little rich , but it seemed to be only at idle, once underway and using the thottle is runs clean, Check to make sure the enrichener is off, and adjust the idle mixture screw. You need to be heavy with the thottle now and then, to burn off the deposits.
If youre smelling gas, you might want to check the float level, if its high itll cause rich running.
Old Jan 10, 2004 | 05:55 PM
dzzy's Avatar
IMO, that model isn't prone to plug fouling at all. You don't give a lot of detail in your post. More typically I've had to richen the mixture screw on most Hondas I've seen, although not so much in recent model years. I would go along with Hondabuster's idea that your choke plunger or cable is hanging up.
Tomtom86
Aug 7, 2024 07:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
KSJOHN
Aug 30, 2015 08:15 AM
scott1988
Aug 18, 2015 08:44 AM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
