400ex sputting in the cold and snow??
Old Jan 15, 2004 | 10:43 PM
yellowexracer's Avatar
Default 400ex sputting in the cold and snow??
My 400ex has a peculiar problem. After ridding for a while it will sputter and stall at anything more than idle or less than full wide open. When i shut it off and let it sit for a while it will start and run good for a while and then start doing it again.
I have a UNI, T-4 slip on and a dynojet kit and i'm running 146 main, 42 pilot 3.5 turns, and 4th clip on the needle.
I did notice some snow in my airbox, could it just be sucking in some water???
Old Jan 15, 2004 | 10:52 PM
Eric250EX's Avatar
might be sucking in water, gets in your gas, dilutes it, making enjine stall? That might be the problem
Old Jan 15, 2004 | 11:43 PM
Oic mabey i'll clean my filter and dump some fresh gas in and see what happens
Old Jan 15, 2004 | 11:56 PM
Quadfather's Avatar
That happened to me once. I found out that I had forgotten to turn the choke off.
Old Jan 16, 2004 | 10:37 AM
I already took the choke off a while ago so that isn't the problem
Old Jan 16, 2004 | 11:57 AM
sixtoe's Avatar
I had pretty much the same problem about two weeks ago. I had to rejet (was running 138 Dynojet which was to lean to begin with and went up to a 146) seemed like a lean condition to me. So far I have not had the same problem. It is running pretty strong right now. I also put a little HEET in my gast tank to prevent things from freezing up. Maybe it was on the verge of freezing up espeicailly if you found snow in the air box/air filter
ultangler
Nov 30, 2024 01:35 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
