2004 Recon ES problem...Help!!
Old Jan 19, 2004 | 10:59 PM
homeslice8's Avatar
Default 2004 Recon ES problem...Help!!
Today, I was riding my brothers 2x4 recon thorugh a stream, about 1.5 feet deep, with ice in it. It got stuck in the ice and bogged out on me. I pulled it out with my grizzly. On dry land, it starts up for about 5 seconds then boggs out on me. I've tried starting it numerous times and it does the same thing. Does anyone have the slightest clue of what the problem might be?
Thanks
Old Jan 19, 2004 | 11:01 PM
bigojaydog's Avatar
You probally got water in the carb check the air box see if there is any water in it.
Old Jan 20, 2004 | 04:26 AM
Coyotechaser's Avatar
While your at it you might as well check to see if the oil is cloudy. If it is , change it 2 or 3 times until all the water is out.
Old Jan 20, 2004 | 02:26 PM
hayve's Avatar
i opened my airbox after riding and all this mud and dirt had got inside so to stop this happening i got some pipe and made a snorkle. All you do is get some pipe slightley larger than the one on your air filter, slip it on, put a clip tight around it. Dont have it to long otherwise the air box cant get air fast enough so i was told. This should help in the future when riding.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
