cracked casing
Old Jan 20, 2004 | 08:08 AM
Csonksters's Avatar
Default cracked casing
This weekend while riding my 85 250R atc, my loose chain came off and cracked my casing (didn't have a chain guard!). Does anyone know the cheapest place to get a new or used casing? Or if anyone has a spare one lying around that ya might wanna sell? Any info would help cause they're all a little pricey locally for me. Thanks
Old Jan 20, 2004 | 11:33 AM
bigojaydog's Avatar
Hey you should try jb weld if u ever herd of it that stuff is seriouse my cuz had the same problem and he used that stuff and it worked perfectly sealed it rite up.
Old Jan 20, 2004 | 12:30 PM
bigblock2stroke's Avatar
I had a similar issue with mine, except it was on the front (i.e. rock in field) and ended up damaging the counter balancing shaft bore to the point where JB just wouldn't cut it. Only way out was to have it welded and then re-bored or just replace it.
I ended up calling
Inland ATV's
25153 Redlands Blvd.
Loma Linda, CA 92354
www.inlandatv.com
They definitely have them new and used. I paid $185 for a used one and it even showed up with good bearings in it. Bolted it right together and have been having fun without incident. That was in September '03
Old Jan 20, 2004 | 01:44 PM
huskerjim's Avatar
does anyone make a case saver for a 400ex this has me bothered....it can happen quick and unexpected.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 20, 2004 | 03:55 PM
bigojaydog's Avatar
Yea dennis kirk sells one part number is 14-8552 $31
Old Jan 20, 2004 | 11:58 PM
Csonksters's Avatar
I would like to use that but. The caseing is cracked by where you shift gears. I had took it to a welder but they had said that they could'nt weld where a seal is. I realy need to buy a new caseing or even a used one in good shape.
Old Jan 21, 2004 | 12:00 AM
bigojaydog's Avatar
try ebay mite find it there
Old Jan 21, 2004 | 12:21 AM
420EX's Avatar
check ebay, use as many search titles as yo can to get the most results
Old Jan 21, 2004 | 12:43 AM
300exrider19's Avatar
ya, that stuff works good!!!
Old Jan 21, 2004 | 12:48 AM
i have used jb weld lots!!!!!!!!!!!!!!!lol[img]i/expressions/face-icon-small-smile.gif[/img]
