Please help with Flywheel 400ex
Old Jan 27, 2004 | 07:32 PM
Sandrider503's Avatar
Default Flywheel lighting advice
Hello I finally got my 400ex into the shop to have all my goodies installed. I was gonna run my headpipe up to LRD to have it ceramic coated. I was discussing this with the service manager and he reminded me about the flywheel we discussed about lighting I just wanted your guys to give me a little knowlege about this proccess. For the cost of the work it sounds like it's worth the money I guess it makes the quad rev super fast and the performance gains are tremendous. From what I hear it can really accent the rev box and cam. I haven't heard alot of talk about this process being done so if anyone has heard any negative things about this process please let me know. So far it sounds like it is worth the 75.00 - 80.00 bucks to have it done just tell me what you think. Thanks
Old Jan 28, 2004 | 02:03 PM
huskerjim's Avatar
Default Please help with Flywheel 400ex
thats a little pricy but the mod is nice to have it will rev like a 2 stroke. it will give you more ponies less it takes to turn the heavy flywheel yes it's worth it.
Old Jan 28, 2004 | 03:48 PM
So you thinks it will rev like a 2 stroke that would be nice. Is there any negative aspects to doing this.
Old Jan 28, 2004 | 05:07 PM
whatwasthat's Avatar
Yeah, there is a negative aspevt. Your power spread wil be altered, and you will have a tendancy to stall at low rpms when in gear
Old Jan 28, 2004 | 06:05 PM
huskerjim's Avatar
low end will hurt just a little....
Old Jan 29, 2004 | 12:49 AM
So my bottom end will be hinderd slighty. Why is that can you explain I was under the impression that if I can keep the compression up and air intake upgraded that the flywheel will just help along with the rest of my mods.
Old Jan 29, 2004 | 09:12 PM
huskerjim's Avatar
The mods your doing will 1. make more hp 2. make your motor rev faster means quicker drags 3. will also give you more torqe. But you have to understand that the flywhell is a little heavy not much compared to a car but enough to slow the rev's down on the motor at low speeds, if you lighten it it will be very fractional what it takes away from the low end for you did bump the compression, So in short with the compression bumped you won't hurt that but you will let it rev even fast and gain HP for it takes less for the motor to turn it meaning quicker drag times. Easier starts as well. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 30, 2004 | 01:31 AM
Hey thanks I really appreciate it you explaned it in lamens terms now things are starting to make sense. So how much power do you think I'll be pushing.
Old Jan 30, 2004 | 02:59 AM
huskerjim's Avatar
If you give me a list of what your doing to your bike I will be able to get real close, the flywheel itself will be 1 to 1 1/2 hp gain with just doing that. thats cheap hp
Old Jan 30, 2004 | 12:20 PM
Hello I will be having a WhiteBrothers R4 muffler, Ceramic coated headpipe, WhiteBrothers all around cam, WhiteBrothers Revbox, K&N filter, MotoForce intake system, OMF airscoops, Flywheel lightened, JE 10.5:1 high compression piston, R/D chromoly valvesprings. That is about it. What do you think. Thanks
