400Ex+Cr500
Old Jan 29, 2004 | 10:46 PM
quadrider654's Avatar
Default 400Ex+Cr500
I am trying to put a honda verison of the suzuki quadzilla and i was wondering if any one out there put a cr500 engine in a 400ex and if any one knows what else i need to put it together and if any one knows of a 400ex for cheap that needs a motor or something.
Old Jan 30, 2004 | 01:22 AM
jstaguy24's Avatar
Default 400Ex+Cr500
I have not seen one in a 400ex frame but I have a cr500 in my suzuki lt250 frame so Im sure you should be able to do it without to much trouble
Old Jan 30, 2004 | 01:35 AM
1986atc250r's Avatar
Default 400Ex+Cr500
I have one in a 400ex chassis. To do it right, it takes quite a bit of fabrication and problem solving. Not a project for the faint of heart for many reasons.
Old Jan 30, 2004 | 09:36 AM
whatwasthat's Avatar
Default 400Ex+Cr500
400ex+cr500= stress cracks in the frame/busted motor mounts and numb hands and feet...
Old Jan 30, 2004 | 10:16 AM
Default 400Ex+Cr500
Cracks - Not if done right.... If you try to cheeze out and attach like a stock engine using 1/8" sheet metal mounts, then yes....
Vibration is only significant at higher RPMs - I'm working on reducing it on mine at the pegs - the bars are not a problem if tackled correctly.
