help 400ex brakes
Old Jul 1, 2000 | 04:07 PM
ruffridaz's Avatar
i have a 00' ex w/ the WB pro-meg system and it has burned a hole in my brake line. how do u bleed the brakes on the ex? whenever i pump up the brake lever shouldnt either fluid leak out of the hole or shouldnt it pump up compression? it doesnt do either one. maybe im just doin somethin wrong? id appreciate any help. thanx
Old Jul 1, 2000 | 04:52 PM
SNELL's Avatar
The best way I have found to bleed the brakes is to take some type if squirt bottle fill it with brake fluid (DOT 4 only) and put a clear tube on the squirt bottle and put the other end on the bleeder and then pump the fluid into the caliper first until the fluid starts pumping out of the reservoir and there are no more bubbles coming out of the reservoir. This will ensure that the caliper is air free because you bled it in the reverse of which the fluid flows. Also make sure you have no leaks at either end of the brake line or it will not be able to be blead. I used thread sealer on my front brake lines. I hope this helps.
Old Jul 1, 2000 | 04:59 PM
Lurch77's Avatar
I would suspect that after the hole was made, most of the fluid leaked out. That could be why you did not have any fluid squirt out.
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
