300EX mods..
Who makes the best black box mod for the 300EX?
I really need to pull my RPMs out of my motor.
Who makes the best high compression piston?
Who makes the best Cam?
And what part of the power will it affect? Low? Mid? Top?
Also, what is a good carb to get?
If you have any other suggestions for mods Let me know.
Thanks
Thanks
WB cdi, Weisco Piston, Web Cam, Kehni Carb (cant spell that). Suggestion: Porting, All angle Valve job. I have weisco, porting, and valve job..and my machine has great low-mid range. With the carb and cam you will have great mid-top. Up to you
you can have them port it for any place you want the power. i.e. mid, top, low. get a keihen carb, WB or TC rev box, wiseco piston (only get a hi-compression one if you want to run race gas), porting, Web cam, valve springs. You can get all this in a kit from TC Racing. look in an issue of ATV Sport and youll find a 300EX hop up story using all the parts from TC. Youll also need a 13 tooth sprocket or 20 inch rear tires. hope this helps.
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
tank10rnk
Aug 10, 2015 08:19 PM
