trx 200
Old Feb 28, 2004 | 02:21 PM
Bradbunchschimpf's Avatar
Default trx 200
does any body know if a 1985 atc 200 cylinder will fit a 1990 trx 200?
Old Feb 28, 2004 | 08:27 PM
KNOWSALOT's Avatar
The Facility
Default trx 200
No. It is a completely different design.
The cylinders you need to be looking for are.......
'86-'87 ATC200X
'86-'88 TRX200SX
'86-'87 TR200 FatCat [Motorcycle]
And another model as yours....'90-'97 TRX200
Old Feb 29, 2004 | 12:22 AM
sharpie's Avatar
Default trx 200
i've read somewhere that the internals of a atc 200s are the same as the atc 200x. is this true??
Old Feb 29, 2004 | 12:27 AM
KNOWSALOT's Avatar
The Facility
Default trx 200
The cam is different and the cylinder has larger cooling fins, but everything else in the topend of the ATC200S is identical to the 1983-1985 ATC200X.
The 1984 TRX200 [only year made....ompletely different from later models] will also interchange with the '83-'85 X top end.
However, the S and X bottom ends are in no way similar other than engine mounts. They are the same.
