WOW
Old Jul 12, 2000 | 11:53 PM
jeepin's Avatar
Today I took my 250r to a high performance atv shop my buddies work at.I took it there to have them see why the front tires weren't linig up with the rears.THey checked the frame over for kinks,bends everything.It had no cracks nothing.So they said they can't figure it out.Then they set the caster/camber,toe/in toe out and got the front end all good and right.THen they gave me about 3/4 tank of 110 octane Vp race fuel with maxima synthtic 32:1 ratio.I let them ride it to see if it felt right.Remember these guys have leagers/paul turner 250r's with PEP shocks the hole 9 yards.They said my 250r handled better than there's.Something about the JD A-arms U can get more camber than the leagers.One guy is switching from leagers's to JD-Arms.They said my motor was running a little rich but it felt like it ripped.This is coming from with paul turner 330's.They where very impressed with my bike.I am glad ,to her that.
86 trx250r wiseco .020 piston,boyesen reeds,porting work,FMF gold series fatty pipe,power core 2 silencer,Dg alloy series nerfs,Motion pro twist throttle,nac's casesaver,JD performance +2 A-arms,white bro's white power shocks with adjustable res's,durablue eliminator 2+2 axle,durablue posi loc axle nut,uni filter,Fastline braided steel brake front brake lines,braking brake pads,PEP easy pull clutch perch and lever,motion pro clutch cable,motion pro kill switch,18/11/8 holeshot mx's on mitchell.190 wheels,21/7/10 holeshots on ITP.190 wide off set .190 wheels,20/11/9 6 ply razr's on ITP .190 wheels,braking brake pads.
Old Jul 13, 2000 | 01:48 PM
Skunky's Avatar
sweet I am using old ford mercury cambers and you can tweek those thing all over the place for the perfect caster/camber,toe/in toe out for what you are riding
Old Jul 13, 2000 | 05:17 PM
philzie's Avatar
Skunky, what are cambers? Please detail an explanation.
Thanks
phil
Old Jul 13, 2000 | 05:27 PM
Skunky's Avatar
It might not be called cambers i think they are...hehe but the bushing that is full of grease that goes on the end of the a-arms that screw into the front wheel hub/brake holder..
Old Jul 13, 2000 | 10:14 PM
supertraprecon's Avatar
ball joints? connect to the spindle?
or the tie rod ends that go to steering stem and spindle?
