350X smokin on start up?
Old Jul 14, 2000 | 01:34 AM
Loofer's Avatar
Hye i have a 85 350X and it smokes on start up and for about 5 min after. when it is warm it is fine. is this because of dried out rubber valve stem seals, like in a car??? or is it something else like rings?? the previous owner said it was recently rebuilt with a high compression piston. if it is the valve stem seals how hard are they to change out?? thanks for any help.
Old Jul 16, 2000 | 01:33 AM
Brad_L's Avatar
Loofer, it does sounds like bad valve stem seals. The cylinder head will have to be removed and disassembled.
Old Jul 16, 2000 | 10:40 PM
350exersizer's Avatar
Mine did the same thing. When you take the valve stem seals off check the stems for small hairline cracks's dont think that you can just cover them up with new seals it wont work. I replaced 2 of my valve guides because they where cracked everything was smooth from then on. I do reget the 12-1 wiseco because of the high octane that you have to run.
1000gade
May 27, 2015 12:37 PM
Mikes350X
Nov 20, 2000 04:04 PM
owen350x
Jul 30, 2000 01:58 AM
YellaTerra
Mar 30, 2000 04:38 PM
projectX
Mar 24, 2000 04:58 PM
