jetting a 450R ?
Old Mar 23, 2004 | 03:41 PM
Quadman07's Avatar
Default jetting a 450R ?
Where did you get your AC nerfs from? Seems everywhere I have called only have DG's
Old Mar 23, 2004 | 04:05 PM
timscherer's Avatar
Quadman07,
Check out ATVADDICTION.COM
Atv Addiction
Tim
Old Mar 23, 2004 | 04:17 PM
Quadman07's Avatar
Thanks Timscherer
Old Mar 23, 2004 | 07:36 PM
CrazyATVDad's Avatar
one last dumb question.
now im playing aroudn with the jet size - i know how to switch the jets quickly -but i havent moved the needle - whats the easiest way to get to the needle ... from the top ??
thx.
Old Mar 23, 2004 | 07:48 PM
  #15
KGB's Avatar
KGB
Just like on a 400ex stock carb. Remove the top cover.
Old Mar 24, 2004 | 10:57 AM
  #16
Quadman07's Avatar
Has anyone changed the sprocket to a 13 tooth? Does it really make a big change?
Old Mar 24, 2004 | 01:10 PM
  #17
KGB's Avatar
KGB
I went tothe 13, it ws to low for me, I went ended up with 13/39. Good combo fro me at the dunes.
Old Mar 24, 2004 | 01:23 PM
  #18
Quadman07's Avatar
Getting mine ready for the track. Playing around out on some trailes it sure seems tall in first gear.
Old Mar 24, 2004 | 01:44 PM
  #19
Warrior1's Avatar
CrazyATVDad,
Are you running with the air box lid on or off? If you have the lid on then a 180 sounds to big plus if you are having a problem 3/4 to full than that would be your main jet. The pipe itself doesn't effect the jetting much the amount of air that you have coming in is what effects the jetting. I am running the stock pipe with the baffle out with a 2" hole in the back of the air box lid. My main jet is a 155, I did not move the clip on the needle.
Old Mar 24, 2004 | 01:46 PM
  #20
Whats the back sprocket - stock ?
it does seem tall - but im still debating if i want to do it.
Does it suffer any on the top end ?
how hard is it to replace the front ?
