Spool Lock !
Old Mar 26, 2004 | 08:36 PM
Loster666's Avatar
Default Spool Lock !
Hey, I just ordered the spool lock from HighLifter . ..
I'm wondering which way I must align my front wheels, Toe-In or Toe-Out, and by how much!?
I suspect that turning diameter will be farther, so, how can I adjust my alignment to have the better ratio between,
turning radius and Handling .. ?
Old Mar 26, 2004 | 09:36 PM
Doctorturbo's Avatar
GOT BOOST!
Loster666, the bad thing about a spool is they only want to go straight. Even if you are going straight, if your tire diameter is different, then it wants to cheat to the short side to make up for the difference in distance. The spool will really try to scrub the tire on the short side of the circle. The long side will try to overrun the short side and it will also scrub the tire in a turn.
Soooooooooooooo, to answer your question, I would set it up to as close to straight up as possible. Although it won't make much difference in the end (towed in, towed out, or straight up) because spools are very hard on tires and equipment in the long run. [img]i/expressions/face-icon-small-sad.gif[/img]
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Fubar008
Sep 1, 2015 07:14 PM
Bratman2
Jul 23, 2015 12:36 PM
