Red Pipes....Cam???
Old Mar 28, 2004 | 11:20 PM
Stevo400EX's Avatar
Default Red Pipes....Cam???
My ex is starting to get red pipes. When I start it and let it idle, no problem. But if I start opening the throttle alittle my headers turn a cherry red. The same problem happens when I'm actually riding it. When I ride it the headers turn red, but when I clutch it, the pipes return to normal color in a second.
What can be the problem?
Please help with any suggestions.
Old Mar 29, 2004 | 01:41 AM
TractorPacker's Avatar
Do you have a balloon?
The carb is too lean.... richen the main jet. Try 160 or bigger?
Old Mar 29, 2004 | 03:16 AM
Yamaha660R's Avatar
It's got a 165 in it now. The spark plug looks good, but could it still be lean even with a gold/tan color plug?
Old Mar 29, 2004 | 09:38 AM
Stevo400EX's Avatar
So I should move up to a 170 or a 175 main jet?
Old Mar 29, 2004 | 02:38 PM
Yamaha660R's Avatar
So going to a bigger jet will help....yes...no???
Old Mar 29, 2004 | 02:48 PM
RoughRider01's Avatar
If you don't have another main jet to try just lower the clip on the needle and see if that helps.
Old Mar 29, 2004 | 05:23 PM
cals400ex's Avatar
don't go to a bigger mainjet, your already too big. i would put in a 160 with the lid off and a 158 with the lid on.
lower the clip on your needle to the 4th position and your problem will get better.
Old Mar 30, 2004 | 05:43 AM
Yamaha660R's Avatar
Alright, we will lower the needle clip.
The jetting is about right the way it is now. I ran the 160 and it was way too lean. So I bumped his EX up to a 165 and it took away on sputters and misses, and makes it run perfect other then the headers. The needle clip is set one from the top, so I will drop it two or three positions, and experiment.
Old Mar 30, 2004 | 03:18 PM
cals400ex's Avatar
the needle should definately not be set at one from the top. it needs to be in the middle or one down from the middle (4th). this is probably why you have to run such a big mainjet. your showing a lean plug because of the needle clip location. i only run a 160 in the winter (cold air is more dense so use a bigger jet) on my 10.8:1 406, stage 2 cam, x-6 exhaust, uni filter, etc. i run alittle smaller in the summer.
