Pinging noise
Old Mar 31, 2004 | 02:05 AM
yaaaaaa's Avatar
Default Pinging noise
Ok i know this is not the yammy section but i am getting fed up with posting something over in that section and all these other people with the same old freaking questions everyday come in and push my important question all the way down to the bottom of a page in less than an hour, hopefully you guys can help me out cuz i am stupmed. Ok i have a 98 warrior that i just rebuilt the top end, every from the block up is new except for the heads, The reason i did this rebuild was because i was way down on power and it was ticking awfull. I just got it all back together and here is a list of things that i did. new valves, stiffer valve springs, weisco piston, stock bore, new cam, new timing chain, and anything else that i may be forgetting is also new, o and i have a K&N filter and adaptor, stock jetting still. but even when it idles it makes this dang tining sound, and when i rev it up it makes this sound also, i have no idea in the world wat it is, any help would be GREATLY appreciated. Thanx alot and again i am sorry for having to post in the honda forum, but the good news is i am getting rid of the yammi once i figure out y it is still piningy.
Old Mar 31, 2004 | 02:08 AM
manual's Avatar
So you put a new piston in, so its probally not that. Are you sure its timed right? Valves adjusted right? You also will tick if you use to low of a octane fuel.
Old Mar 31, 2004 | 02:15 AM
yaaaaaa's Avatar
Yep valves are set to specs, and the timing is right on. i belive the octane level i run is either 89 or 93
Old Mar 31, 2004 | 02:18 AM
manual's Avatar
When you put the piston in, did it have any play?(not normal rotating), but could it go side to side and kinda wiggle?
Old Mar 31, 2004 | 02:21 AM
yaaaaaa's Avatar
Yeah i could move it side to side on the wrist pin.
Old Mar 31, 2004 | 02:24 AM
manual's Avatar
That there could be causing it. Not sure if its ok to have a little or not. Could be your bearings also.
Old Mar 31, 2004 | 02:25 AM
yaaaaaa's Avatar
Nah the movement on the wristpin is normal. Yeah i never did change the main bearings just cuz they are a pain to get to.
Old Mar 31, 2004 | 02:26 AM
manual's Avatar
I read through what you have and you still have stock jetting on all that stuff? You would notice a big increase if you rejetted.
Old Mar 31, 2004 | 02:29 AM
yaaaaaa's Avatar
yeah, i need to get that orderd really badly. I am getting to the point where i dont want to put any more money into it cuz i have put to damn much into it allready, i just want to find somebody to buy the damn thing so i can go out and get my either a 400ex or 125cr
Old Mar 31, 2004 | 02:37 AM
manual's Avatar
LOL. Im at the point on my 300ex where im not ever gonna sell it due to how much I plan on putting into it. Gonna lose couple grand to much if i sell it. After my 300ex is built I will probally save up some cash and build up the raptor.
