Squeaky shocks
Old Apr 5, 2004 | 03:35 PM
haulin's Avatar
Default Squeaky shocks
Hey folks, I just bought a new 03 250ex for my wife and the front shocks squeak like the dickens! I removed them and lubed where the attach to the a-arms and the bolt with white lithium grease and it really didn't help much. I know it's kinda petty, but it's annoying as hell! Any suggestions?
Old Apr 5, 2004 | 04:06 PM
Trevor's Avatar
It is likely your A arm buchings not the shocks. I had the same problem with my 2002 300EX I just sprayed the bushings with lube and that worked for me. My problem was the A arm bushings
Old Apr 5, 2004 | 04:21 PM
haulin's Avatar
That might be a possibility, although when I took off the shocks, I moved the a-arms up and down to confirm that it was the shock and there was no noise when just moving the a-arms.
Old Apr 5, 2004 | 05:51 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The 250EX is famous for this! I sprayed some WD-40 up inside the shocks (at the dealers suggestion), and it didn't seem to do much. But it seems to have improved somewhat over time.
Old Apr 5, 2004 | 08:21 PM
Chilly's Avatar
Try a silicone spray lube on the bushings.
Old Apr 5, 2004 | 10:00 PM
keepitpinned's Avatar
Trevor i own a 300ex n have the same problem. The noise pisses me off. this might sound retarded but wut are the a-arm bushings? Are they the little rubber things on the a-arms. Just spray lube on them?
Old Apr 5, 2004 | 10:45 PM
SANDMAN430's Avatar
i'm also looking for the fix to this problem'
Old Apr 6, 2004 | 03:41 AM
URCRAZY's Avatar
I brand new A-arms, and shocks put on my 400 and they squeak also. Very annoying, makes your bike sound like a piece of crap. Have a bad A$$ looking quad and pull up to a bunch of people and squeak squeak and they all look at you.
Let me know if you get your sound fixed.
[img]i/expressions/face-icon-small-blush.gif[/img]
Old Apr 6, 2004 | 07:53 AM
dzzy's Avatar
Don't know if this helps but on Ranchers, the squeak comes from the metal collar inside the mounting holes for the shocks. Simply remove and grease with your favorite lube.
Old Apr 6, 2004 | 08:24 AM
haulin's Avatar
That's what I'm saying. I already did that. I'm going to take the shocks out again this weekend and spray them with "One Lube". That stuff gets anything apart! I'll let you guys know the outcome.
