ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   Do i have to premix fuel on a 86 atc 250R (https://atvconnection.com/forums/honda/148195-do-i-have-premix-fuel-86-atc-250r.html)
754 04-06-2004 10:44 PM
I dont know a lot about 250Rs so could someone give a anwser on this please. Thanks for any replies
havinnoj 04-06-2004 11:31 PM
Yes
maddog56 04-06-2004 11:37 PM
If you are getting one you should learn fast. On those 15 year old 2 strokes top end rebuilds and re ringing are common afternoon activites.
DaBeechMan 04-07-2004 07:42 PM
guess you better stick to your 4-stroke then
I havent had to do a top end rebuild in 2 years.
Mix your fuel at 20:1 until you get the hang of your jetting. Then once you figure out what is going on you can go to 32:1
400excrazy 04-15-2004 05:02 PM
always pre mix your fuel------
shocker 04-15-2004 05:48 PM
You should be fine with 32:1. 20:1 tends to be too rich. but it also depends on if there are any mods or a rebuild. Knowing a little history of the bike will help. But like I said earlier, 32:1 will be sufficient.
